953 wagon hubs
Larry
03-28-2003 10:58:03
Does anyone know if the hubs are interchangeable between the early cast hubs and the later models without the screw on caps?
Leroy
03-30-2003 10:26:06
 Re: 953 wagon hubs in reply to Larry, 03-28-2003 10:58:03
Bearings and seals were changed in 64, used different wheel, changed with serial no. 10101
Back spindles all same no. A 5251 DW
Front to 59 one no. changed in 60 to anouther older sub new
Unless you have the brakes then only one style hub to fit
jls
03-30-2003 08:53:55
go harass the JD dealer. I just got the parts list and blow-up of a 902 wagon gear and the 951 is also listed. you will just have to compare the parts numbers of the bearings to see if they match.
