Badger round bailer info
same as Vermeer 505?
horsefarmer
04-02-2003 13:47:01
Hi, bought a Badger round bailer at auction. Tag on it says same as (made by?) Vermeer 505 or Massey 125. I can't find any data plate on it - just safety stickers. Looks to be about 5'dia x 4' wide bales. any info on this, or any tips on operation? I have Oliver 1365 60HP - big enough to run this bailer? the Oliver runs a 24T JD square bailer W/Hyd kicker fine.
Thanks
P.S. I have pics I can e-mail if it will help identify it.
horsefarmer
04-03-2003 07:11:45
 Re: Badger round bailer info - same as Vermeer 505? in reply to horsefarmer, 04-02-2003 13:47:01
Thanks for the info, guys. Anyone have an idea where they hid the data plate on this one? Also the "C" channels are twisted in the area where the Hyd cyl opens the bailer to eject. Is this a problem with Vermeer 505C? I'm thinking of putting a rectangular tube across the area with gussets to keep it from flexing....
DENNIS KOCH
01-04-2006 18:36:30
 Re: Re: Badger round bailer info - same as Vermeer in reply to horsefarmer, 04-03-2003 07:11:45
HI I AM THINKING ABOUT BUYING A VERMEER 555 SILAGE BAILER IS IT ANY GOOD OR SHOULD I LOOK FOR A DIFFERENT MAKE PLEASE E MAIL ME THANKS.
Carter Carter Machinery
04-03-2003 06:52:18
The Badger is the same as a 504C baler and is a closed throat design. Worth $500-$1000 depending on the condition of the rubber roller.
marlowe
04-02-2003 16:03:27
it is a Vermeer they made them for massey and badger you can get parts from a vermeer dealer we have a massey 450 and get what we need from vermeer. we just use after market bealts
JD 4020 Gas
04-02-2003 15:13:10
Miller Pro bought out Badger. Maybethey can help you. (800) 247-5557
