Belt for belt pulley
Randy
04-03-2003 07:36:45
Does anyone know where I can buy the wide type belt for use on my tractor clutch pulley? Thanks in advance for any help.
Leroy
04-05-2003 10:41:08
 Re: Belt for belt pulley in reply to Randy, 04-03-2003 07:36:45
There has been many posts on this in the past, most agree that baler belt will not work as it streches and does not have the strength
Paul Janke
04-05-2003 14:26:55
 Re: Re: Belt for belt pulley in reply to Leroy, 04-05-2003 10:41:08
I have a baler belt which I have been using for a buzz saw for between five and ten years now. It seems to stretch lots less than the fabric belts I have which were made for belt drive use. The fabric ones which are about 40 feet long probably stretch at least 6" during use after being unbelted for weeks or months since their last use. I use a come-a-long to keep them tight, so I just keep going another notch every few minutes for probably about an hour.
Philip
04-04-2003 09:49:12
Randy, Try your yellow pages. I found a guy in Indianpolis that stocks belts, the crimp piece ends, and the wire tie. I told him it was going on my retored 8N with a Dearborn cord wood buzz saw. I took pictures to show him. He made the belt for free. Philip.
les Davis
12-10-2006 16:28:34
 Re: Re: Belt for belt pulley in reply to Philip, 04-04-2003 09:49:12
My dearborn (Buzz Saw) works well when it is sharp. I know there is someone out there that knows an easy way to sharpen my saw blade. Please let me known. Thanks Les
Robert in W. Mi.
04-03-2003 08:18:31
You can buy the belt at most tractor dealers as the belting is used for big round balers. My local Tractor supply (TSC) has it too. It comes in bulk rolls, so they will cut off what ever length you want. They also have different widths. Robert
Randy
04-03-2003 08:40:25
 Re: Re: Belt for belt pulley in reply to Robert in W. Mi., 04-03-2003 08:18:31
Thanks Robert.
