IH baler with a motor on the bale thrower
Charlie
04-05-2003 14:40:00
I saw a model 37 baler today with a bale thrower that was powered with a small gas motor on the baler. I have a model 46 on which I've seen a direct drive shaft from a belt driven pully on the fly wheel to the bale thrower. Is the model 37 an older baler than the 46 and and it was IH first attempt at a bale thrower or was a separate motor an option.
ihkovas
04-06-2003 20:12:04
 Re: IH baler with a motor on the bale thrower in reply to Charlie, 04-05-2003 14:40:00
Charlie,
The model 37,along with models 27 and 47 were built after the '50s model 46 baler. I think 37 came out early 1960's. In a brochure I have for the model 46 it says about the bale thrower: "Cleated rubber rollers on the No 10 Bale Thrower take the bale as it leaves the chamber and toss it into the wagon. Bale thrower has its own air-cooled engine. Just speed it up to load the rear of the wagon...slow it down to load the front...all from the tractor seat!"
Leroy
04-13-2003 09:35:44
 Re: Re: IH baler with a motor on the bale thrower in reply to ihkovas, 04-06-2003 20:12:04
Had No. 46 baler with No. 10 thrower, all PTO powered, no motor
Hugh MacKay
04-06-2003 14:58:48
When my New Holland Super 69 was new the first thrower I had was gas powerwed by a Briggs engine. It never worked very well. Broke three crankshafts the first season. It had a flywheel, but it just seemed that little crank couldn't stand shock of bales hitting belt. Before the next season NH did a recall and replaced entire thrower with their new pto drive unit, no charge. I thought that was indeed a good jesture.
RickB.
04-06-2003 04:21:41
Neighbor used to have an IH with a Briggs powered thrower. IH bale throwers are easily identified by the absence of thrower belts. They used 3 rolls above and below the bale to toss it into the wagon. Tim, Ludke did build throwers for both Ford and Allis.
Tim(nj)
04-05-2003 14:54:25
I wonder if that was an after-market thrower? I believe Sears sold one in the catalog. A-C had an engine-drive thrower, too, made by Ludtke? I think Ford may have used it too. Probably the same as the Sears unit. Or, somebody fitted up the first New Holland thrower to that IH baler.
