Cheap manure spreader
Grass Roots Far
04-05-2003 15:48:07
We have several large piles of manure from chickens and cattle. We need to move such piles to about 1/4 acre plot of land which will be plowed and tilled for crops. Any "homemade" suggestions for moving and spreading other than a cart to carry and my husband to spread the manure mix?
willyz
04-13-2003 04:33:20
 Re: cheap manure spreader in reply to Grass Roots Farmer, 04-05-2003 15:48:07
Try this. Get a 4 or 5 prong manual manure loader the kind with the wooden handle. Use it to load the manure on your wagon, trailer, pickup, or even wheel barrow. Haul to plot. Either park unit and spread around and move to another spread area and repeat, or have someone move it for you while you spread. Works great, costs little, is a great phyisical workout.
paul
04-07-2003 05:57:38
The rear scoop idea has a lot of merrit. Small working manure spreaders have a lot of demand, so they tend to cost a lot or are totally wore/rusted out.
My concern is 'large piles' of manure. You shouldn't put too much manure on crop land, and 1/4 acre is pretty small. I'm concerned that you could overdo it. Is this manure composted, or pretty fresh? Will these large piles be applied every year to this 1/4 acre?
There are many regulations facing farmers these days, with record keeping, on manure application. While your small size may let you fly under the radar, it might be wise to follow about the same goals, and not over-apply manure.
Esp chicken manure, it can be very hard on new seeds.
Now, to me a 'large pile' of manure takes a whole day for me to load & spread on 10 acres with my spreader & loader. Your version of a large pile might be quite a bit less. :) But a 1/4 acre is pretty small, don't over-do it.
--->Paul
tim[in]
04-06-2003 17:54:37
you might also consider borrowing a spreader from some one local if you are going to continue raising livestock..plus by composting the manure you will stablize the manure and make it not so likley to burn. it will also be much easier to apply and handle. it will also lose the objectional odor that neighbors might whine about. just make sure piles are moist and turn the piles every so often. either way you can also apply it during the growing season as fertilizer and a moisture preserving mulch.
mj
04-06-2003 10:19:31
You can move the piles with a rear mounted scraper bucket mounted to the tractors' 3-point . Turn it backwards and back into the piles if they are too tall to drive over. Dump the bucket in the field "on the fly" and then spread with a drag made from old tires with one side wall cut out ...cut side down. You can fasten 3 of these tires to a drawbar with chain, 1/4" cable and clips or #9 wire. Fasten 2 behind the 3 and one more behind the 2. You don't want them up tight to each other so leave some slack in your chain/cable/wire so the tires can 'float' a bit. Hook the drawbar to your tractor hitch at the center of a another length of chain that spans most of the drawbars' length and you're in business. :-)
jim
04-06-2003 07:03:02
Just a word of caution. Don't apply a lot of poultry manure in any one year as it is considered a "hot" manure and if overly applied could burn your crop. Better to spread it out over two years rather than one. Cow manure should be no problem, again in moderation.
Remember , nature takes its course and you'll have to build your garden up over a few years.
