Ez-on offset disk
karl f
04-08-2003 23:52:21
we have an ez-on offset disk that needs blades, bearings, and some other maintenance. I cannot find any reference to the brand in aftermarket parts catalogs like shoup. and have no idea where to even find a dealer. the one we purchased from has been out of business for roughly 20 years.
can anyone help me with a parts source, and other info?
this is a big piece of equipment that is pulled behind a ~120hp tractor, and takes almost all of the hp available.
thanks
-karl
JMS/MN
04-10-2003 15:49:11
 Re: ez-on offset disk in reply to karl f, 04-08-2003 23:52:21
Remove a bearing and a blade and take them to a local dealer to compare measurements with what they have for an offset disc. The bearing itself should have a mfr number that the dealer can cross-reference for you. Center holes and their design are fairly standard among several makes. Spacer4s, etc. may be more difficult to duplicate, but they can be handmade from common steel material instead of cast iron.
