469 Haybine
jeff flahrty
04-09-2003 13:27:44
Can someone tell me what the center distance between the tires is on that piece of equipment?
Thanks,
Jeff
RickB.
04-10-2003 17:15:41
 Re: 469 Haybine in reply to jeff flahrty, 04-09-2003 13:27:44
Probably just wide enough NOT to fit on an 8' truck or trailer bed.
markct
04-10-2003 18:36:34
 Re: Re: 469 Haybine in reply to RickB., 04-10-2003 17:15:41
thats why ya gota load it sideways and take the tounge off of it
Frank
04-10-2003 15:21:14
I have a 479, which should be close to the same size as a 469. My overall width is 146", with 11L x 14 tires. This dimension is within a couple of inches of the outside-outside tire dimension as the (reel drive) shield on the right projects slightly past the tire.
Hope that this helps.
