IH 2-14 on rubber
Farmer in the D
04-13-2003 11:10:52
I have a plow that has many of the same features as the one in a recent post. Other than it is on rubber (6.00 16) which appear to be original and it is a 2-14. The tail wheel is the same and it is a ground turn. There are two numbers, one on each plow arm but I suspect they are part numbers. If need be I will post them here later. Any idea on model?
mike in mn
04-16-2003 13:13:38
 Re: IH 2-14 on rubber in reply to Farmer in the Dells (WI), 04-13-2003 11:10:52
you have a little genius number 8. I have got three of these. neat little old plows.
kj(il)
04-13-2003 18:52:40
farmer in the dells, have a 1 bottom plow and a 2 bottom plow both are # 8 built at P&O works, I know for a fact the 1 bottom was bought new in 1936. the lift on both are the same.
Hugh MacKay
04-14-2003 03:41:38
 Re: Re: IH 2-14 on rubber in reply to kj(il), 04-13-2003 18:52:40
kj: Do you have a manual or any other literature, for that single bottom plow. I am not suggesting this plow doesn't exist. There is another thread earlier on this plow posted by FM along with a picture, same plow as Farmer in Del has posted, so there is no question the plow does exist.
We have been unable to find anything on paper saying IH ever produced a single bottom No.8 Read the thread below and give us your thoughts. If you have any printed material on this plow, I am sure Mike and some others would like to hear about it.
mike mn
04-16-2003 13:17:14
 Re: Re: Re: IH 2-14 on rubber in reply to Hugh MacKay, 04-14-2003 03:41:38
go buy the book called 150 years of International harvester. that plow is in there.
Hugh MacKay
04-16-2003 14:34:38
 Re: Re: Re: Re: IH 2-14 on rubber in reply to mike mn, 04-16-2003 13:17:14
I have the book 150 Years of IH and there is no single furrow Little Genius picture, however there is a single furrow Little Wonder.
mike in mn
04-16-2003 21:32:37
 Re: Re: Re: Re: Re: IH 2-14 on rubber in reply to Hugh MacKay, 04-16-2003 14:34:38
they did make one. it looks just like the two bottom minus one. thats the only difference. other wise I wouldn't have the one I got.
Hugh MacKay
04-17-2003 02:58:25
 Re: Re: Re: Re: Re: Re: IH 2-14 on rubber in reply to mike in mn , 04-16-2003 21:32:37
Mike: When I come to a discussion like this and the other discussion on the same subject, I read all the discussion that has taken place before I start sniping at someone. I is quite obvious you have read very little of this discussion, as I at no time have said this plow doesn't exist. May I suggest you take the time to do some reading.
I have a John Deere model 400 7' rotary hoe, John Deere never built such an item. IH may never have built some items that are out there either.
kj(il)
04-14-2003 18:54:11
sorry sure dont the lady i got it from told me she remembered the day her dad got the plow , disc 2 row cultivator and tractor, she thought it was an f14.
Hugh MacKay
04-14-2003 19:17:25
 Re: Re: Re: Re: IH 2-14 on rubber in reply to kj(il), 04-14-2003 18:54:11
kj: She is no spring chick if she remembers that, then again she is probably only ten years older than I. That must have been quite an event getting a new F-14, plow, disc and 2 row cultivator all on the same day and in the late 1930s. Probably was a $1,500. purchase, a lot of coin in the dirty thirties. There were however, farmers thrifty enough to do this, tractor production numbers speak loud and clear.
hugh MacKay
04-13-2003 11:46:08
There is no question on a 2 furrow with these same features including the tail wheel. And yes even on rubber as they were available that way. It is a Little Genius No. 8 They were built from 1928 to 1960. I suspect rubber tires came in 15 years following the war. The only plow in question is this single furrow, in print they don't seem to exist. Read the other thread down the page.
04-13-2003 14:04:08
 Re: Re: IH 2-14 on rubber in reply to hugh MacKay, 04-13-2003 11:46:08
Thank you Hugh. Figured you would know and was hoping you would reply. So until I hear different, a little Genius #8 it is. If I get ahold of a camera I'll get a picture of it on the implement picture page.
04-13-2003 14:02:41
