Identifying a Ford Dextra 2000
Mikie
04-17-2003 03:35:01
Need help in identifying an old tractor that we just got. Has Ford Dextra 2000 on the front and 3 sets of serial numbers.Thanks.Any help would be appreciated.
Mikie
04-18-2003 14:29:55
 Re: Identifying a Ford Dextra 2000 in reply to Mikie, 04-17-2003 03:35:01
Tony,
Thanks for the help. A neighbor came by and told us it's a 1959 Dextra and proceeded to walk us through the needed repairs.
Thanks again,Mikie
Tony
04-17-2003 16:49:50
If your tractor is UK built, the serial number will be stamped on the right side near the join between the clutch housing and the gearbox.
From November 1957 to November 1961 all serial numbers were prefixed 957E. After November 1961 the prefix was 1961 09A 1962 09B 1963 09C 1964 09D
Dexta engines also had serial numbers. Diesels started with 1500000, petrol FPL27. All numbers are stamped. The cast numbers are casting ID and do not help identifying the tractor. E-mail me the number and I will give you the year.
