Ferguson hay rake
Tony
04-20-2003 17:42:26
I've got a Ferguson model D-E0-20 side rake that I can find no info for on the web. I want to get it running again. It's a 3-pt mount, PTO drive with a belt, 6 raking bars, about 7' raking width, and two caster wheels in back. Did it later become a M-F model that I could find info on?
TNX - Tony
Tom A
04-22-2003 08:16:01
 Re: Ferguson hay rake in reply to Tony, 04-20-2003 17:42:26
Tony:
If you search this site's archives for DEO 20 and/or DEO 25 (don't use a hyphen with this search), you'll find about a dozen entries.
I've got one of each model, the 25 is a little wider and heavier built than the 20. They were later renamed, as I recall, MF 25 and 20 and production carried on thru the early-to-mid 60s. Some parts and the manuals are still available from Massey Ferguson.
They're decent rakes--built like a tank--although the -25 makes my 8N tractor's front end a little light.
good luck,
Tom
Tony
04-25-2003 13:41:06
 Re: Re: Ferguson hay rake in reply to Tom A, 04-22-2003 08:16:01
Thanks for the tips - I'll give it a try. You're sure right about being built heavy. Even tho it was very rusty, I passed up a New Holland 55 for the same money at the auction because this rake looked sturdier.
Tony.
Leroy
04-20-2003 18:50:43
Email me if you want more information, Leroy
