Hydraulic problem on a MF loader
Rick
04-21-2003 11:21:52
I have a MF loader with a front mounted pump. I am not able to lift the bucket. I am getting fluid out to both lift cylinders and am getting fluid to return. One cylinder attempts to move a half inch or so and the other one wont budge. I let the system get real low on fluid and had added fluid back to normal. Since that time, I have been having problems and I have been told that I could have an "air lock" in the cylinder. A fella at a local hydraulic shop said my spools were bad in my valve but if that were the case, why would I send fluid to the cyliders and have it return back. I disconnected the one lift cylinder from the loader to see if the one that was trying to lift could lift the bucket by itself but did not work either. If I did have air trapped in the cylinder(s), could air in one or both of them prevent the cylinders from lifting? Any replies are greatly appreciated. Puzzled in FlatRock.
