Hay cutter?
Heath
04-27-2003 20:21:55
Im just getting into the hay business. I have a JD 4430, JD 430 bailer, and an 8 wheel rake. (Notice anything missing?) I need a cutter. Plan to cut mostly costal in central texas. Debating between a 3pt disc type cutter with no conditioner, and a JD 12ft sickle type with conditioner. I cant make up my mind and my hay is getting tall!! Please give me and advice/pros/cons.
Thanks
Heath
James in NC
04-28-2003 09:28:30
 Re: hay cutter? in reply to Heath, 04-27-2003 20:21:55
I would go with the 3pt disc cutter. If your only cutting costal it really does not need to be conditioned. The disc cutter will also be faster. I recomend the Krone disc mowers they work great. If you want faster trying time a tedder would be better for costal than a conditioner.
