Broadcast seeder
Jack
04-29-2003 05:45:12
What can I use to put out grass ,brome and orchard seed over a few acres. Are those 3pt broadcast seeders any good or is there a better way to do it?
thanks
Brent
04-30-2003 18:16:14
 Re: Broadcast seeder in reply to Jack, 04-29-2003 05:45:12
Use a Brillion seeder, or equivalent type drop spreader. Brome seed will not flow or spread well through a spinner/broadcast seeder. Seed/soil contact is #1 and the Brillion will roll it into close contact for you after spreading the seed.
greenbeanman
04-29-2003 22:06:30
Some counties here in Kansas have grass seeders they loan out. Some counties share a common one for loan. Might check with the county where you are at to see if they know of one available.
TomH
04-29-2003 18:38:50
Broadcast is okay, especially if you pull a packer behind it. You might be able to rent a grass seeder for not too much.
Jason
04-29-2003 08:52:00
I found a neighbor who had a brillion seeder with the two packers -one forward of seed drop and one back of seed drop site. Other post is correct - have a good seedbed ready. The brillion seeder worked great and was very uncomplicated.
smirkey
04-29-2003 06:20:42
seedbed prep is probably the most important part. i suggest plow, disk, (make sure everything is dead) pack with some kind of packer, seed then pack again. seed to soil firm contact is the primary job.
