CASE HAMMER MILL
D-SPANGLE
05-06-2003 09:09:11
DOES ANYONE KNOW WHERE TO BUY POSSILE REPLACEMENT PARTS FOR A 10INCH CASE HAMMER MILL I NEED THE PIPING FROM THE MILL TO THE BLOWER IT APPEARS TO BE SIX INCH IN SIZE THANKS DAN
ken
07-27-2003 19:35:50
 Re: CASE HAMMER MILL in reply to D-SPANGLE, 05-06-2003 09:09:11
I see you must have the same mill I have. Do you have any idea when it was made? Where can I get a book or history on this and does yours have the bagger unit on it?
IDJunker
05-07-2003 06:28:38
If you are trying to replace the U shaped pipe from the bottom of the mill to the blower try 6" sucktion hoes for a pump or leaf vac work great on mine. Just leve about 3" to 4" of old pipe to clamp on to.
Good luck.
Steve
05-06-2003 14:54:02
Dan you might try some regular ol stove pipe that you can get at the local hardware store. I have used it before and it worked fine. On some mills the flange on the opening for the discharge is rectangular and 6" pipe won't quite go over it. If this is the case with your mill you can take a piece of 8" stove pipe and use tinsnips to form it and then poprivit it together. It is a bit of work but works quite well when you are through. Good luck
