Custom Rates
Casey in Ky
05-06-2003 17:30:45
Anybody have any idea as to what the going rate is for a 60hp tractor, 7ft disc mower(NH615), rake and tedder, a small square baler(NH565) and a 4x4 round baler(NH630). Would prefer hourly rates on the mower, rake, and tedder, and by the bale on the balers as most around here aren't real for sure of exactly how many acres they own, if you know what I mean.
Thanks,
Casey
hntndaylight
05-07-2003 18:26:14
 Re: Custom Rates in reply to Casey in Ky, 05-06-2003 17:30:45
I'm in central KY. By the bale I charge $7.00 to roll minimum of 30 rolls. Cut $50.00 per hr, rake $38.50 per hour for single, $50.00 for a double. Rolling by the hour is $80.00 plus twine. Minimum is 4 hrs, travel time 1 way included. By the roll, cut, rake and roll $12.00.
Josh
05-07-2003 09:14:41
I live in south eastern PA and do a little custom baling. I charge $1 per 40lb bale but may raise to $1.10 this year. If you split it down, I get $.40 for baling, $12 per acre for mowing. With a disc mower you can probably do 3? acres per hour so I would charge $35-40. Maybe charge a little less per hour with the tedder and rake. The rate guide is the best way to go, but I usually try to charge around $30 per hour and then adjust my acre charge according to how much I think i can get done.
James
05-06-2003 18:43:30
Your county extension agent should have a booklet available for you showing custom rates from one or two years ago. I just picked mine up for Kansas.
