501 sickle mower hook up
mike
05-07-2003 08:34:06
I need some help. I've never hooked one of these up and have some parts missing. The arm that goes under the left lift arm on tractor and raises and lowers cutter bar when lift is raised or lowered. Does it need to be clamped tight to the lift arm where it cannot slide or does the arm with the ball on the end of it do this. As you can see I'm in the dark. Thanks in advance for any help. Also I'm cutting bahia any idea on pto rpm i need to run with an MF 135 and what about ground speed 3 low gears and 3 high gears.
paul
05-07-2003 09:53:32
 Re: 501 sickle mower hook up in reply to mike, 05-07-2003 08:34:06
Did you ask a week or so ago? I was too busy that day.....
I run it on my 960 Ford, so I hope things fit on your tractor the same....
I hook up the lower left 3pt arm first, as it is often the lowest. Raise the 3-point a bit, & hook up the right side. Un-pin the upper arm spring (where it slides on the top link - early models had a bolt, newer models have a pin & clip - get a pin & clip!) and attach the upper arm. Attach the pto (MAKE SURE it clears on the way up - runs very close to max in on my tractors!). Lift the mower, attach the upper spring pin. Lower the mower. Attach the clamp on the lower left side to the 3-point arm - clamp it on tight.
Ready to mow.
If you clamp that arm a little forward, the mower won't raise as high. A little rearward & it will lift higher. Only takes a small amount, an inch difference. You will get the feel for it quickly - I don't like it raising too high myself.
For rpm, I run about 1/2 throttle. On my 5 speed Ford I run in 3rd gear.
However, in thick, short, or damp grass or fresh clover I've been down to 1st gear, about wide open & cussed the whole time. Then again in dry thin alfalfa I've been close to idle in 4th gear.
You need to play with speed & rpm to make it work right. Sometimes doing the opposite of what you think will actually improve the cutting.
--->Paul
