Bell Crank loader on 8N?
lrb111
05-07-2003 13:06:58
I don't know if i'm dreaming this or not.. Has anyone ever seen a loader that uses bell cranks below the rear axles and cables to raise a front end loader. It works off the standard rear riser bones of the 3 point. Has a roller guide on each side for the cable about midway up the trans housing. tia..
Larry
Taylor Lambert
05-07-2003 20:31:42
 Re: Bell Crank loader on 8N? in reply to lrb111, 05-07-2003 13:06:58
I think those were manure loaders. ive seen them from a distance and want a close veiw so i can make a few. The one i saw in a book lifted about six feet high.
lrb111
05-07-2003 21:45:56
 Re: Re: Bell Crank loader on 8N? in reply to Taylor Lambert, 05-07-2003 20:31:42
That may be it.. What i'm seeing in my head was really lightweight framework. I don't need a real heavyweight loader. The bucket needs to be just wide enough to carry enough dirt to fill a tire for a rammed earth/tire fence. 200 pounds max.
Thought about it all day. Think i'll dummy one up out of plywood and 2x4s before i commit to welding. Maybe check the library first.
lrb111
05-07-2003 21:43:45
