Ford 540 baler
Frank Fox
05-08-2003 21:23:24
I just picked up a Ford 540 baler, needs work on the pickup guides that carry the hay up to the auger. And the center bearing support on the PTO shaft. It came from the origional owner and he gave me the origional owner's manuel. I will use it behind my 1951 8N. Will use it on my five acre's as a hoby. Frank Fox, Sacramento, Ca.
Jim.UT
05-09-2003 15:21:03
 Re: Ford 540 baler in reply to Frank Fox, 05-08-2003 21:23:24
Another FBBA member! (That stands for Ford Blue Baler Association). It's a loosly organized (?) group of "dare to be different" types. Jerry D is the chairman and will be in touch!
Jim.UT who is slowly resurrecting a 542 for use behind his Ford 850.
Tom A
05-09-2003 05:08:31
You're a lucky duck, that's all I can say. Congratulations!
Tom A
'48 8N
Frank Fox
05-09-2003 23:26:16
 Re: Re: Ford 540 baler in reply to Tom A, 05-09-2003 05:08:31
I will let you know how lucky this duck is after I cut and smash and generaly bang up the body putting things in order on the 540. You are right, when I bleed, I bleed FORD BLUE. Can any one tell me how much this thing weight's? I had to tow it over three hundred miles to get it home. It towed fine, dident know it was behind me at fifty five miles per hour. Started towing it at thirty five MPH and ended up at fifty five. I would like to find a parts manuel for it, any suggestions? Thanks, Frank in Sac.
Frank Fox
05-09-2003 23:26:06
Tom A
05-10-2003 02:43:32
 Re: Re: Re: Ford 540 baler in reply to Frank Fox, 05-09-2003 23:26:06
New Holland sells reprints of almost all old Ford and Dearborn stuff, so I'd start by calling their publications department at 800-635-4913. I've found they're fast and friendly, and all the manuals I've bought from them have run around $8-$12.
Not familiar with your specific baler, but my old small square balers both weigh in at just over a ton each.
Tom
Frank Fox
05-10-2003 22:04:14
 Re: Re: Re: Re: Ford 540 baler in reply to Tom A, 05-10-2003 02:43:32
Thanks Tom. Frank
Frank Fox
05-09-2003 23:24:55
