Farmall Super A Plow
Josh
05-10-2003 10:12:34
Does anyone have some detailed pictures showing how the one bottom plow is attatched to the super A tractor they can send me? Thanks in advance. Josh
Hugh MacKay
05-10-2003 17:47:45
 Re: Farmall Super A Plow in reply to Josh, 05-10-2003 10:12:34
Josh:
I don't have any pictures nor could I send them. I think I can help you though. Are you satisfied that you have everything needed. Do you have the rockshaft between and mounted on rear fenders, just behind seat? And do you have the pull rod that goes from the rear rockshaft to the hydraulic unit rockshaft beside fuel tank? Do you have these items on the tractor? Do you have a U shaped adjustable height drawbar? Apart from these items mentioned describe all other items with plow other than plow itself. Get back to me with this and we will go from there. I just want to be sure you have it all, and I think this can help insure we are using the same terminology.
