FMC Brush Hog
Tony
05-13-2003 13:53:57
I have an FMC brush hog that is leaking bad out of the gear box. Does anyone know where I can get a new seal for it?
dg
05-14-2003 07:19:37
 Re: FMC Brush Hog in reply to Tony, 05-13-2003 13:53:57
The same seals are used in many applications. If you can get the seal out without tearing it up or just get it cleaned up you should be able to read the numbers pressed in the seal. Any "good" auto parts should be able to get for you if they don't have it in stock.
James
05-14-2003 12:14:11
 Re: Re: FMC Brush Hog in reply to dg, 05-14-2003 07:19:37
I just went through what you are doing. If you can find a dealer who knows the part number, that is the way to go. If you take the seal out yourself, make sure not to damage the side that has the part number on it. If you can't see the part number, they will be on the underneath side. Do not pry against the under side with anything, or you may damage the numbers. My auto parts store refered me to a company here in Kansas City called IBT. They sell most any type and size of oil seal. My part number was no longer available, but they got me a seal based on the shaft diameter and the housing diameter.
Charles
05-13-2003 14:11:43
HERCULESSERVICEPARTS.COM HERCULES SERVICE PARTS IN MINDEN, LA CAN HELP YOU WITH ALL YOUR SIDEWINDER PROBLEMS CALL 1-800-566-8359. ASK FOR PAUL OR KEN
Charles
05-13-2003 14:11:23
SIDEWINDER MANUFACTURING
07-20-2006 15:30:24
 Re: Re: FMC Brush Hog in reply to Charles , 05-13-2003 14:11:23
FMC SIDE-WINDER/BUSH HOG IS IN BUSINESS THEIR PHONE NUMBER IS 1-800-343-5825 THE NUMBER HAS NEVER CHANGED.
THERE IS A NEW OWNER AND LOCATION, BUT WE CAN AND WILL SERVICE ALL OF YOUR SIDEWINDER NEEDS.
LOOK FOR THE WEBSITE "UNDER CONSTRUCTION" NOT UP AND RUNNING AS OF YET www.side-winder.com
jcor
08-02-2005 16:19:35
Gilcrest Equipment purchased the Side-Winder mower from FMC. WWW.GilcrestEquipment.com/
Jay
07-20-2006 15:37:35
 Re: Re: FMC Brush Hog in reply to jcor, 08-02-2005 16:19:35
FMC SIDEWINDER/BRUSH HOG IS STILL IN BUSINESS AND CAN SERVICE ALL YOUR NEEDS. WHOLE GOODS, PARTS ETC. THERE PHONE NUMBER HAS NEVER CHANGED IT IS
1-800-343-5825. THERE IS A NEW OWNER AND LOCATION. BUT STILL GOING STRONG. THEY PLAN TO GO BACK INTO PRODUCTION SOON. WEBSITE "UNDER CONSTRUCTION" NOT UP AND RUNNING AS OF YET www.side-winder.com
CALL
jcor
08-02-2005 16:31:21
Also Sidewinder and other farm equipment parts can be obtained from Quality Parts (in Kansas?) 1-800-626-1260.
Blades can be purchased from Tractor Supply Co. located in most states. They can order if not in stock. Try www.myTSCstore.com to locate stores.
Jay
07-20-2006 15:54:47
 Re: Re: FMC Brush Hog in reply to jcor, 08-02-2005 16:31:21
FMC SIDEWINDER IS STILL IN BUSINESS WITH A NEW OWNER AND LOCATION. THERE NUMBER IS THE SAME 1-800-343-5825.
CALL FOR ALL YOUR PARTS ETC.
jcor
08-02-2005 16:27:45
Jay
07-20-2006 15:47:09
 Re: Re: FMC Brush Hog in reply to jcor, 08-02-2005 16:27:45
THERE NUMBER HAS NEVER CHANGED 1-800-343-5825
CALL FOR ALL YOUR PARTS OR WHOLE GOOD NEEDS.
05-01-2006 09:10:11
HERCULES SERVICE PARTS HAVE ALL THE PARTS YOU NEED FOR THE FMC MOWERS PLUS THEY KNOW WHAT YOU ARE TALKING ABOUT. WE WORK THERE FOR TWENTY YEARS
