Gimme Opinions on NH Hay Eq
Bear
06-04-1999 07:10:11
Have found following old stuff in storage, all looks good for age; opinions please as to working same.
NH 269 sq baler NH sickle mower
NH hay conditioner (Not a cutter - just conditioner that can either be powered by tractor or by attaching to the above sickle mower)
New Idea rake, no model # visible.
Widow farmer wants $1700 for kit n kaboottle.
Pros - Cons ?
Bear
06-06-1999 06:31:50
 Re: Gimme Opinions on NH Hay Eq in reply to Bear, 06-04-1999 07:10:11
Status Update:
Old Baler looks good - knoters well lubed and not broken up/welded. No kicker.
Mower solid - not pitman.
Rake so-so.
Conditioner, of course, best piece of lot.
Price down to $1500
Tanks for advice on price; what about "usability" factor on model 269 baler? Problems?
Bear
Tim(ny)
06-07-1999 05:26:29
 Re: Re: Gimme Opinions on NH Hay Eq in reply to Bear, 06-06-1999 06:31:50
I have a 268 with thrower, and am happy with it, except for the fingers (4) that feed hay into the chamber. I believe they went to 6 to correct those problems in the later 268 and 269 models.
paul
06-04-1999 21:05:54
Would be a little high around here, but if it's a good 2 wheel rubber tired hay rake then everything is pretty good stuff. If it''s an older 4 wheeled rake walk away...
--->Paul
B.C.
06-04-1999 11:17:32
If the rake is on rubber tires that might not be too far off if it's all in good shape. If it's a steel wheeled four bar, then the baler better be really primo.
You might try to have a competent disinterested 3d party give an opinion of it all.
James
06-04-1999 10:46:01
I'm looking at a NH 7' sickle bar mower and 7' conditioner for $300. $1700 seems high, but depends on your locality.
wayne
06-04-1999 09:43:52
I would say it is high. But I don't know the condition on it either. N.H. is among the best in hay equipment.
Tim(nj)
06-04-1999 20:09:11
 Re: Re: Gimme Opinions on NH Hay Eq in reply to wayne, 06-04-1999 09:43:52
Well, the NI rake, if it is a 402 , would be worth around $700 here, in good shape (a good rake is hard to find). The 269 baler would be worth $350 if it has a chute, $500 if it has a thrower. The sickle mower, if it has a balanced head, would be worth $400, if pitman arm, $250. The conditioner would be worth $25, regardless of what condition it's in. So that's not too far off, by New Jersey standards, anyway.
