Bed shaper/ bed former
barnaby
05-23-2003 15:21:45
Has anyone built or designed a bed shaper? It looks like something that could be locally manufactured with toolbar adjustability for spacing, etc. Thanks
Hugh MacKay
05-24-2003 04:40:50
 Re: Bed shaper/ bed former in reply to barnaby, 05-23-2003 15:21:45
barnaby: I built one of these 12 years ago, and yes I agree if you see one in an auction probably the way to go. Unless you are in the right area you may wait a long time for that. Mine is just a heavy piece of channel mounted on fast hitch in my case. 3 point would work just as well. In the wheel tracks I have a real heavy lister type hoes, about 6" below channel. I also use a potato type hiller on center mount tool bar. That helps a lot in bringing soil in to shape bed. I have these set almost 36" bringing it in to a row. By doing this you don't need to drag as much soil as the unit on behind is levelling that row as well as bringing soil in from both sides.
I found before I used the hiller on front it took several passes to shape a bed from tractor wheel to wheel. If you have any questions e mail me.
chuck
05-23-2003 17:16:34
in sw az they can be bought at auction for just a few dollars-less than $200 4 row. i dont think u could build one for that unless u already had the metal and many of the parts.
