Ford 501 mower hookup
Jeff
06-04-1999 14:58:06
3 pt won't raise this mower more than 3-6 inches off ground. WIth mower off 3 pt raises 250 lbs no problem. Could I be hooking this up so it is binding. My concern is the top pt and the stabalizer that hooks under lower pt arm. Suggestions?
Dan Chambers
06-09-1999 12:36:49
 Re: Ford 501 mower hookup in reply to Jeff, 06-04-1999 14:58:06
Inrefeance tothe lower left hand arm it is connected to the tension spring that controls the weight tension exerted by the outside shoe. The pushrod attached to the left end of the spring should move freely when not attached to the tractor. If it does you're ok. The toplink should be in the lowest hole for toplink attachment under the seat. There should be another small arm that attaches to the toplink then to the large spring. If all else fails get a reprint of the operators manual from your New Hollan dealer, they are available. Mine cost $11.43. Could be your hydrolic pump in your lift system. Good luck. Dan
DD
06-04-1999 17:25:49
Now keep in mind I'm not at home looking at my mower now. But if I can picture it correctly, the left (looking at the back end of the tractor) stabilizer which is bolted to the lower 3pt arm activates a big spring when the mower is raised and lowered. If you trace the stabilizer from the 3pt arm to the spring it goes through a section of the mower which has a couple of grease fittings. My only thought is that if things are frozen in there it may impede your ability to raise the mower. Only an idea. Good luck.
