469 haybine
Jeff
05-26-2003 08:30:21
Any thoughts as to why my 469 Haybine seems to get grass balled up along the cutting bar and guards? I replaced the cutting bar already and have experimented with different ground speeds. Would reel speed be a factor? This is just pasture grass and it's not that thick.
Tim
05-26-2003 13:53:14
 Re: 469 haybine in reply to Jeff, 05-26-2003 08:30:21
Is the grass being cut but not moved on to the conditioner rolls, or not being cleanly cut? If the grass is too thin and short it may be real hard to get it to feed evenly.
Tim(nj)
05-26-2003 09:42:44
Are the reel teeth set close enough to the cutterbar to clear the grass off?
Jeff
05-26-2003 10:57:05
 Re: Re: 469 haybine in reply to Tim(nj), 05-26-2003 09:42:44
Now that you mention it, I'm not sure. Guess that will give me something to check.
mike
05-26-2003 18:44:41
 Re: Re: Re: 469 haybine in reply to Jeff, 05-26-2003 10:57:05
are your blades close enough to the bottom of the rock gaurds making a good sissors type cut?
