Case disc
keith
05-26-2003 19:07:04
I have a 12 foot case disc that leaves a large mound of soil in the center after discing. How should it be adjusted so it won't leave the mound?
Hugh MacKay
05-28-2003 08:33:30
 Re: case disc in reply to keith, 05-26-2003 19:07:04
Keith: You have your back gangs set too deep if its wheel controled. Levelling crank should correct it. If a drag disk angle is too sharp on back gangs. Angle could also be too sharp with wheel controled also. The tractor may have enough power now, that you are going too fast, that will also have an effect.
