Cutting back out of bushhog for hay mowing
Ridr
06-01-2003 07:30:48
Has anybody heard of cutting the back plate out of a bushhog and using it to mow hay with ?? An old man here says that by cutting the back out, it throws the hay out the back instead of mulching it up and works better than a sickle bar mower .
Tractor Dan
06-01-2003 11:10:45
 Re: cutting back out of bushhog for hay mowing in reply to Ridr, 06-01-2003 07:30:48
you can mow alot faster with a sickel bar
hay
06-01-2003 10:48:18
cut out the left side and the back all the way up to where the back end of the right side panel is. that way the cut hay will exit out fast and not get chopped up so much. tail wheel will run over some and help crush it too. hay cures faster when cut with a bush hog. done all my hay cutting like that for several years now.
Dan
06-01-2003 10:13:51
Have seen adds for some fo the rotary mowers with a removable back or side for cutting hay that way. Have also seen discussions on YT board about this. Have never seen anyone do it but guys say it works great. I bought a King Kutter a year ago and in the parts book it shows a model with removable back. I would think it would not work well with real tall hay.
Chip S.
06-01-2003 11:33:34
 Re: Re: cutting back out of bushhog for hay mowing in reply to Dan, 06-01-2003 10:13:51
Does OK for second cutting, but for tall timothy and orchardgrass it doesn't work real great. It's slow, breaks up the leaves of the hay a lot, and doesn't drty real good, unless you have a tedder. I also found it was kinda tough on the mower, a 6' dual spindle Woods.
