501 mower adjustments
azglide
06-01-2003 17:29:14
Been messing around with a Ford 501 mower I picked up the other day and was wondering how to adjust the lead and trail of the bar. (manuel has been backordered) Archives has a lot of good information but didn't see this addressed. Looks like the end of the bar is about 8" - 10" farther back than it should be. Any help or sugestions until the manuel arrives is greatly appreciated.
tlak
06-02-2003 02:45:15
 Re: 501 mower adjustments in reply to azglide, 06-01-2003 17:29:14
They have a safety deal incase you hit a rock and your just suppose to back up with it on the ground to engage.
azglide
06-02-2003 15:49:41
 Re: Re: 501 mower adjustments in reply to tlak, 06-02-2003 02:45:15
It appears to be as far forward as it will go. Old mower is in pretty good shape, just don't think the bar should be that far back and don't see anywhere to adjust it.
Hayman
06-02-2003 21:07:49
 Re: Re: Re: 501 mower adjustments in reply to azglide, 06-02-2003 15:49:41
The bolts on the inside shoe are on an eccentric lobe and that is how you adjust tour lead.Sounds like yours has been BENT back to be back that much.
paul
06-02-2003 19:01:20
I'm not even sure how it should be adjusted, maybe just shims in the yoke, but the far end of the bar should be leading by a little. Trailing is bad....
Have you checked the bushings where the bar rotates up & down? They could be quite shot it be trailing by a foot.....
--->Paul
