Case model 170 hay rake
Dan Chambers
06-09-1999 08:42:57
I need an operators manual for a Case 170 hay rake.It was probably manufactured between 1941-45,has two large tires in front and two "wobble wheels" in back. The rake bars are adjusted at either end by long levers that project towards the front. The rake teeth can be adjusted forward or backward with a lever in the center.The bars are Case red/orange and the main frame and tongue assembly are pretty close to John Deere green.My Case dealer is unable to order an operators manual.Any info would be appreciated. Thanks Dan
