5 bottom Oliver 3 pt moldboard plow
Mark A
06-05-2003 10:03:57
What kind of HP would this plow require? I dont know the size of the moldboards. Would a 3020 JD gas handle a plow this size? Thanks in advance.
larry
06-06-2003 18:20:22
 Re: 5 bottom Oliver 3 pt moldboard plow in reply to Mark A, 06-05-2003 10:03:57
we had a 4x14 oliver semi mounted on a 72 hp 1650 we pulled at about 5 mph but it was light on the front end again it depends on soil type and hard pan we did plow at 9 mph till we hit that rock broke 2 shares one shot
paul
06-05-2003 10:28:47
Do you mean a 2-point with trailing wheel plow? An actual 3-point 5 bottom plow would sure be heavy!!!!! You need to hang a lot of weight off the front to balance it.
Plowing depends a lot on your ground conditions, and you didn't tell us where you are or what your ground is like. Dad had a 3-16 trailing plow he used with an Oliver 88. Some years he plowed in 4th gear. Some years it took a second tractor with a car tire chained between to plow alfalfa with it. Most of the time he was in 2nd or 3rd gear. I plow with a 135hp tractor & a 4-18 plow. Most of the time I have extra power, & can be moving right along. Some years, I need to drop 2 gears, & the front end will lift up, tires will want to spin out - that's with a dual on & rocks in the rockbox. So you need to plan for those tough years, as well as looking optimistaclly at the best plowing conditions.
Where I am, a gas 3020 would handle a 3 bottom plow. In looser, sandier soils, I hear people can use a 4-16 on a diesel 3020 - seems pretty optimistic to me tho. Not here - we have wet heavy clay ground.
Where I live, a few people have tried a 5-bottom on a 4020, but it's a lot better to have a 4-16 on a 4020. Here a 5-bottom plow needs 120hp plus to make it work year in & year out - and some years are difficult at that.
So, while it may possibly work in some special light soils, I sure wouldn't try it.
--->Paul
thurlow
06-05-2003 11:05:54
 Re: Re: 5 bottom Oliver 3 pt moldboard plow in reply to paul, 06-05-2003 10:28:47
As Paul says, a lot depends on your type of soil and how deep you want to plow; having said that, I can't imagine a 3020 pulling a 5-bottom under any condition..... ...
JMS/MN
06-05-2003 22:26:41
 Re: Re: Re: 5 bottom Oliver 3 pt moldboard plow in reply to thurlow, 06-05-2003 11:05:54
A lighter frame, non-reset 4 bottom plow on a 3020 is max- a 4-16 or 18 is a good match for a 4020. Five bottoms on a 3020- no way, even in sandy ground.
