Front bucket assembly
Kevin H.
06-06-2003 00:02:40
I have a Cub Low-Boy 154 with a Front End Loader. What I would like to know, is there such a thing as a higher pressure hydrolic pump for this tractor? This thing will only pick up about a 1/3 bucket of dry dirt. I am told that they will only pick up about 200lbs from the factory. Is this information correct? And if there is not a higher pressure pump, then could you tell me if there is any way I can increase the amount of bucket lift? The hydrolic tank is full, however, one of the tilt rams is leaking a very little bit.
paul
06-06-2003 08:55:44
 Re: front bucket assembly in reply to Kevin H., 06-06-2003 00:02:40
Is the loader frame, tractor front end, etc. able to handle more weight? Sometimes the hyd are derated to match what the iron can handle.
--->Paul
Ric Ks
06-06-2003 05:56:30
An Expensive way to solve the problem is to replace the lift cylinders with larger diameter, the more surface to push on the more lift, never was around a Low-Boy but maybe you could pick up a pair at salvage. May have to have extra reserve tank if needed.
