Kuhn hay cutter question
flyingvranch
06-06-2003 17:55:51
I just bought a used Kuhn cutter (GMD 700 HD) and I need to replace the blades. I noticed that the blades are currently mounted with the bevel of the blades facing down towards the ground. Is this correct? It looks like they should be mounted with the bevel facing up as in a conventional lawnmower blade. Any help would be appreciated!
Glenn Lingard
06-06-2003 18:21:13
 Re: Kuhn hay cutter question in reply to flyingvranch, 06-06-2003 17:55:51
On all makes of disc mowers, the bevel of the blades face upwards.
cannonball
06-08-2003 06:02:29
 Re: Re: Kuhn hay cutter question in reply to Glenn Lingard, 06-06-2003 18:21:13
have you ever run the mower he is talking about..when looking at the blade both bevels are on the same side ...so one way it is looking up and when u turn it, its facing the ground...have nice day may god bless
Glenn Lingard
06-08-2003 17:39:19
 Re: Re: Re: Kuhn hay cutter question in reply to cannonball, 06-08-2003 06:02:29
We've used various makes of disc mowers for 30 odd years or so and are currently running a New Holland disc mower, When the blades are new, and have eventually wore on one side, you take them off the disc that is rotating say clockwise, and replace them with the disc turning in the opposite direction. Does that answer your question?
cannonball
06-09-2003 04:37:08
 Re: Re: Re: Re: Kuhn hay cutter question in reply to Glenn Lingard, 06-08-2003 17:39:19
nope these stay on same disc...they are twisted and boy don't try to run them on the wrong disc, lol i made a mistake and did that on new idea..will pull your tractor real bad..have nice day may god bless
Glenn Lingard
06-09-2003 17:37:22
 Re: Re: Re: Re: Re: Kuhn hay cutter question in reply to cannonball, 06-09-2003 04:37:08
OK, so your mower uses reversile blades, but the original question was, which way up, even yours are bevel side up arn't they?
cannonball
06-09-2003 19:37:25
 Re: Re: Re: Re: Re: Re: Kuhn hay cutter question in reply to Glenn Lingard, 06-09-2003 17:37:22
nope the kuhn gen 2 700 hd the bevel is on same side so one side will be up and when you flip it the bevel will face the ground...in fact just started season with new kuhn and the blades came from kuhn with bevel facing down...so it goes back to what kind of mower you have..new idea has bevel on each side..so bevel will be up..vicion is the same way..kuhn gen 2 700 hd nope...have nice day may god bless
Glenn Lingard
06-10-2003 18:27:35
 Re: Re: Re: Re: Re: Re: Re: Kuhn hay cutter questi in reply to cannonball, 06-09-2003 19:37:25
Mine is a 617 New Holland disc mower, much the same design as yours, 3 point mounted, 9ft 2inch cut, bla, bla, bla, We bought it new 4 years ago and it came with the reversible type blades, We cut around 385-400 acres a year with no problems so far, the blades are changed about every 200 acres or so, How wide a windrow does your mower leave, ours is about 5 feet.
Regards.
