Cutting hay with brush hog
JOHN
06-07-2003 18:56:09
JUST STARTING OUT WITH MAKING OWN HAY.
DONT HAVE ANYTHING ELSE TO MOW IT WITH.
THE SIDE AND REAR COMES OFF THE BRUSH HOG.
HOW IS THIS GONNA WORK?
WILL IT TAKE LONGER TO DRY OR WILL IT DRY QUICKER? THANKS IN ADVANCE FOR YOUR INPUT.
jeff
06-09-2003 20:27:55
 Re: cutting hay with brush hog in reply to JOHN , 06-07-2003 18:56:09
It will work, you will need a tractor with some horse power though if it is thick hay. I found a 5' mower was too much for my 9n to cut the field clean. I lost about 40% of my crop at least compared to what I got from the same field with a sickle bar. It does dry nice. If you field has any size to it you will use up alot more time and fuel because of overlap too.
Jim from Ohio
06-08-2003 05:10:51
We had a 5 ft. Bush Hog(brand name) when I was a kid on our farm. Mowed a lot of hay with it. Worked great. Cows liked the hay better and didn't waste as much because it was chopped up finer. Dries quicker too. I remember one day we mowed in the morning and baled dry hay in the evening. Perfect weather conditions though. Hope this helps. God Bless.
