Dearborn 2-14 model 10152 plow
john
06-10-2003 08:10:34
I am looking for points & shins for my plow. Any suggestions?
Clancy
06-12-2003 09:58:03
 Re: Dearborn 2-14 model 10152 plow in reply to john, 06-10-2003 08:10:34
John-----
I believe these people can help you out.
Good Luck
Clancy
Crescent Forge and Shovel
405 W. Tinkham
Havana, Ill. 62644
309-543-3348
Jerry D in NC
06-11-2003 07:25:17
I think you can get them from most NH dealers still but if not then the shins are available by mail order from Agri Supply for $7.99 each and the rockshares (points) are available for $8.49 each for the 4 bolt 14 inch points. I am in no way affiliated with Agri Supply other than having spent enough with them for parts and pieces to fill a truck.
john
06-12-2003 09:33:17
 Re: Re: Dearborn 2-14 model 10152 plow in reply to Jerry D in NC, 06-11-2003 07:25:17
Jerry D I thought I had a 14"-2 bottom plow but I am not sure. The shares are a two bolt that hold the shares to the plow moleboard, not 4 . How do you determine the size of the plow. By the way I measured the width of the beams that hold the moleboard and it measures 12" between the beams. HELP!!!
Phil (VA)
06-12-2003 10:23:45
 Re: Re: Re: Dearborn 2-14 model 10152 plow in reply to john, 06-12-2003 09:33:17
Then you have a 12 in. plow, not 14. Try Ky-Tenn in Kentucky. Or Joe Erb in Sugar Creek, OH. You can get phone numbers off web or from information. I don't have them handy. I know Joe has some parts for these plows. You need the full number off the back of the part you need. Or you might get by by having the number off the back of the moldboard.
Scott
06-10-2003 18:21:19
There is a number on the back of each item, if you local New-Holland (was Ford and Dearborn) dealer doesn't have them contact me.
Burlgoat
06-10-2003 15:17:32
John I carried mine to the local welding shop he made me a new pair.He charged me 50.00 for everything.You might want to try that route.
Rick
06-10-2003 12:16:00
third party image
I have a 2-14 dearborn plow you can buy. It has the original skins and points on it, I think.
I am asking 295.00
I live in Ann Arbor, Michigan area.
