IHC 13 run seed drill with steel wheels
Al Tribineviciu
10-25-1998 15:45:49
Please explain the numbers on the seed drill shaft. There is an adjuster on a slide with a little square window. I think it adjusts the seeding rate for grain. What do the numbers stand for?
Clint Hofstetter
10-26-1998 11:43:36
 Re: IHC 13 run seed drill with steel wheels in reply to Al Tribinevicius, 10-25-1998 15:45:49
: Please explain the numbers on the seed drill shaft. There is an adjuster on a slide with a little square window. I think it adjusts the seeding rate for grain. What do the numbers stand for?
The numbers correspond to seeding rates on the charts in the seed hopper. If yours is like many the charts are either missing or unreadable. You might be fortunate and get something from a Case IH dealer. I had one of those drills and was able to find a owners manual and copy it. I have now one of the rubber tired drills, operates the same and uses the same charts. Contact me if you want to know more.
