IH sickle mower ID help?
ksguy
06-11-2003 10:27:19
I picked up an IH sickle bar mower (red in color) that has the model number 'worn' off the id plate. The ID plate says it's an International Harvester and the serial number is stamped in but apparently the model number was painted on?. It is belt drive 'wobblebox' type, 3 point with no trail wheel, on the frame the painted on model number is 4 digits and ends with 00 (so maybe 1000,1100,1200,1300 from the 70's from my search here?) - can't tell what the first frame number is, second number may be a 2 or 3 (as in 1200 or 1300?). It uses an extra cable hookup to the tractor to raise the bar when the 3 point is lifted, and the bar sits on an a-frame type bracket with a single large headed carriage bolt and l-bracket hold down with the bar back across the mower when in 'travel' position. The bar has to be lifted manually to get it in travel position (and it's one heavy bar). The wobble box has 2 chrome hole plugs over the zerks to grease the wobble box and a yellow decal that warns not to overgrease it. It has a metal mow/swath board. Since I need to get the outer runner for the bar and the IH dealer isn't sure how to ID it, any help would be appreciated. I could arrange for pictures if that is of help.
Thanks in advance for any ideas.
Dale from Indiana
06-11-2003 19:03:20
 Re: IH sickle mower ID help? in reply to ksguy, 06-11-2003 10:27:19
Sounds like a 1300 to me. I have one just like it. There is a setup manual for auction right now at this site and the bid is $3.00. May want to try and buy it. Couldn't go wrong if it does't go to high.
Hugh MacKay
06-11-2003 16:04:52
I have copies of the 1983 and 1984 IH buyers guides. 83 lists 1000, 1100 and 1300, with a picture showing the 1300 as the 3 point model. No other pictures but the other two would be trailing and side or center mount.
The 84 guide lists only 1100 and 1300, again one picture showing 1300 as 3 point model. I hope this helps.
Brian in MO
06-11-2003 19:40:35
 Re: Re: IH sickle mower ID help? in reply to Hugh MacKay, 06-11-2003 16:04:52
Hugh, the 1000 is a semi-mount with a single wheel I have one.
