Freeman 25a baler anyone used one ????
mike
06-12-2003 23:44:56
i have one i inherrited have used it off and on but was never real happy with the bales courious if anyone else had gotten one to bale nice square bales thanks mike
G706
06-14-2003 22:09:30
 Re: freeman 25a baler anyone used one ???? in reply to mike, 06-12-2003 23:44:56
Baled with one for about 20 years before getting a Freeman 200 in 1991 so I'm going from memory. That can be a real trick to make square bales. The most important thing is to drive correctly with the windrow centered on the header and the baler making at least 20 strokes per bale and preferably the same number of strokes in each bale. If you try to overfeed the baler it is hard to make nice bales. The feed fork adjustment is critical. You can adjust the stroke and vary the position and number of teeth on the feed fork. If you bales are longer on the cut side lengthen the feed fork arm. If they are longer on the far side then shorten the arm or remove or put a shorter tooth on the rearmost tooth position. If you don't have an operator's manual contact J.A Freeman in Portland, Oregon. They should still have those. Make sure the bearings in the feed fork crank arm are tight. It's no fun to bale the feed fork.
