Grimm hay tedders
markct
06-13-2003 10:15:46
last week i was at an auction and they had a 2 spinner grimm tedder, it had belt drive and just common pillow blocks for bearings. looked very simple and trouble free. does anyone have any opinions on these, do they work ok, or do the belts slip or anything? i bid on that one but stopped at 200 bucks cause i wasnt sure what it was worth, there is one in the paper for sale localy and i was thinking of going and looking at it tho
Bill Gould
03-28-2004 11:33:16
 Re: grimm hay tedders in reply to markct, 06-13-2003 10:15:46
I have used a super 8, two spinners, for sixteen years and have only had to replace a tire and some tines. Bought it used without the basket and paid $ 750.00. It is easy to adjust and except for grease it is mantainence free. I am looking to sell it and buy a larger Grimm tedder.
Harold Hubbard
06-15-2003 06:34:21
I bought a four spinner one several years ago as a backup for my Kuhn tedder. It has become my fulltime tedder, and the Kuhn is backup. I would buy another if I needed one. The belt drive is simple and reliable. I take the tension off the belts when I store it for the winter, and keep it under cover. Most of the parts are stock industrial bearings or assemblies welded out of standard steel shapes. That said, if you are buying one, make sure the belts are in good shape, the two short ones are about $100 each, and the long one maybe $125. The wheel/tire assemblies are a sore point, you have to keep them tight, or the wheels wobble on the hubs and ruin both of them. The company has come out with a new design with a welded in hub that fixes this. I use this tedder on about 80 acres of Vermont hill farm every year.
I deal directly with the factory on parts, G. H Grimm Company, Rutland Vermont 802-775-5411, ask for Don.
Bernie
06-13-2003 18:35:50
I've used one of those tedders for the last eight years. The belts do have to be kept tight, but it only takes a few minutes. One thing, you have to slow down on the corners or the outside wheel,going faster, will throw the hay into the next windrow. Wind will do that too, however the height of the kick is easily adjusted. If it's windy just barely lift the hay. I found for best results the windrow should be flipped first so the ground dampness is on top. I put a hitch on the back of my wheelrake to pull the tedder so I do it all in one trip, with all but two or three wheels chained up.
Frances Page
06-03-2005 07:37:07
 Re: Re: grimm hay tedders in reply to Bernie, 06-13-2003 18:35:50
Where can you obtain belts for the Grimm tedder ? Thanks for your help.
Tractor Dan
06-13-2003 13:20:25
well they arnt a bad tedder we had one on the farm for many years then we up graded to new holland shaft drive liked that as well but you will hear as many people bic!h about the shaft drive ones as others do the same for the belt drive i do remmeber once they had to put new belts on and not sure price but it was expensive but dont believe it would be as much as shaft and gear box both my niebors run grimm tedders and they like them as well if price is right there worth it hope this helps good luck
