Coulter positioning
chaney creek
06-22-2003 19:42:22
I am having problems positioning the coulters on a 4 bottom iron wheeled plow so it doesn't get plugged up. The field I am trying to plow was bushogged recently and the windrows left in the path of the cutter get caught up in the plow. The grass was pretty high and the cutter doesn't have a great mulching action even with a homemade plate on the rear opening.
The windrows go the long length of the field.
Any suggestions about the coulters and also the cutter?
chaney creek
06-23-2003 18:23:19
 Re: coulter positioning in reply to chaney creek, 06-22-2003 19:42:22
Thanks for the info. I have a 6 ft. disk harrow and used it a while and it seems to cut and turn it under some to speed up the decomposition process.
Roy in UK
06-23-2003 14:19:59
As others have said, if its "loose at both ends" now no way will it go under, all it will do is bung everything up.
JMS/MN
06-23-2003 08:45:07
I remember one mfgr saying adjust the coulters to run just forward of the point of the share, and 5/8 inch to the left. Now that's really picky! You might also try plowing with no coulters, especially if it is a low clearance plow with small coulters. Sometimes that plugs less. Paul's comment about the 720 is accurate, I have the same and even the extra length and clearance of 18 inch bottoms does not guarantee smooth sailing.
J Kirsch NY
06-23-2003 07:18:41
We used to plant rye for a winter cover crop. There would be times when we wouldn't get to plow as soon as we would've liked and the rye would be two feet or more tall. We then attached a heavy wire to each coulter shank and let it drag a few feet behind the plow---constantly being plowed under. This caused the rye to be pulled down and covered more easily by the plow.
Hugh MacKay
06-23-2003 07:47:39
 Re: Re: coulter positioning in reply to J Kirsch NY, 06-23-2003 07:18:41
I think you and I have crossed paths before, you with wire and I with chain, they both work great as long as one end of plant is attached to ground.
Jim
06-23-2003 10:29:53
 Re: Re: Re: coulter positioning in reply to Hugh MacKay, 06-23-2003 07:47:39
Hugh, wires and chains are cheating, just set the jointers correctly (about 1 1/2" deep).
Jim
Hugh MacKay again
06-23-2003 16:53:43
 Re: Re: Re: Re: coulter positioning in reply to Jim, 06-23-2003 10:29:53
Jim: I notice these Middlesex County boys don't seem to be out honeing their plowing skills on Saturdays as in the past. Usually on Sat mornings you see them early at coffee shop with pickup, trailer, tractor and plow. They must be feeling confident about competition in surounding Counties.
Hugh MacKay
06-23-2003 11:31:15
Jim: It may well be cheating but it works in corn stalks and 2-3 foot grass. Jointers will work up to a point, but there is a point beyond.
Hugh MacKay
06-23-2003 03:51:11
Paul is right, only one way to plow trash, its got to be hooked at the stump. The job you are trying to do would only serve to break in a clergyman, then you would have to take him off for getting words in order training.
paul
06-22-2003 20:52:15
You're scr**ed. Let it rot away & plow later.
Plow the standing stuff, _don't_ mow it first next time.
Even my hi-clearance 720 IHC plow would have a tough time.....
--->Paul
Mike Hager
06-23-2003 09:01:39
 Re: Re: coulter positioning in reply to paul, 06-22-2003 20:52:15
Remow it and set it on fire, that is the weeds of course. Short of a Disk Plow, that's it.
paul
06-23-2003 06:05:05
To be a bit more informative on my part:
Big coulters, as big as possible, help. My hi-clearance plow can have 20 or 22" coulters - bigger is better. Most of the time, very close to the plow bottom is best. Most of the time, plowing when it is very dry (no rain, no dew, low-humidity wind) can help. Once in a while plowing _during_ a gentle rain will work better, but that is unusual to get conditions that work.
The more distance between each bottom, the better chance of this working for you. This is not ajustable - old plows generally have bottoms close together & low plow beams that make things difficult. They also probably only have 16" coulters, can be worn down to much smaller. Makes trash handling nearly impossible. BIG coulters are the biggest help.
At this point, disking the field a couple times might help. Wait a week for the mess to decompose a bit - a little rain would help that process, plus firm up the ground again. Perhaps re-mowing the grass with the brush hog will help speed things up. Anything that chops it finer or pushes it into the soil at all will help a bit. Being able to plow kitty corner or cross-ways to the 'windrows' will help a bit - can't change the direction of plowing, but mowing it in a different direction is possible.
But, you have a difficult task now any way you look at it if you need it plowed right away. It is much better to leave the grass standing & attached & try to plow it that way. Then the crop material will (mostly) flow through the plow.
--->Paul
Paul in Mich
06-23-2003 11:42:00
 Re: Re: Re: coulter positioning in reply to paul, 06-23-2003 06:05:05
Plowing 'off kilter", or kitty cornered to windrows or the direction the field was planted in general, plus using serated culters tend to chop and reduce the field trash that causes plows to plug up. In extreem cases where Rye, wheat straw, or even corn stubble is heavy, it is even helpful to run a bush hog over the field to break down some of the growth before mold board plowing or chisel plowing.
