Case #10 Pull Type Sickle Bar Mower
Daniel
06-25-2003 13:04:47
I have a Case #10 Sickle Bar Mower that I would like to use, but I can't figure out how you lift it. If someone has one like mine that could take a picture of the lift or has a parts manual for one and could send me a picture in an email I'd sure appreciate it.
dave
06-26-2003 09:39:37
 Re: Case #10 Pull Type Sickle Bar Mower in reply to Daniel , 06-25-2003 13:04:47
I have an owners manual for an E10 case mower.
Leon in MN.
06-25-2003 19:00:33
I don't have a picture of one but the way we used to use ours was it mounted up to the 3 point arms and the third link the usual way, then I believe near the drawbar it had sort of a lever arm coming out with a small length of chain attached to the end of it. The chain was then fastened (or bolted)to the drawbar through the hole in the drawbar. When the three point was raised, the lifting action put tension on the chain (thus trying to lift up on the drawbar) and would raise the cutterbar via the linkage. Hope this helps, Leon in Mn.
