IH fasthitch c-20 plow bottoms
dan
06-28-2003 05:08:04
I am in the process of restoring one of these and since it has a original plow chief on the back needing some parts and another type on the front needing a lot of parts is there a new type of 14 in bottom I could just replace them both with? I don't care that much about originality as long as it will work and I don't have to modify the frame.I haven't had any luck at all finding plow chief parts so somebody please help!!!
Hugh MacKay
06-28-2003 11:59:05
 Re: IH fasthitch c-20 plow bottoms in reply to dan, 06-28-2003 05:08:04
Dan: Did you look at the possability of using Super Chief. At one time I had 2 - No.60 trailer plows, both were 4x16. One had Plow Chief bottoms and the other had Super Chief. I never tried to match these up with on another, but I am almost certain you could trade them around, as in trading the complete bottom. There should be a plentiful supply of 14" Super Chief bottoms just about anywhere in North America. CaseIH should be able to tell you whether they will interchange. Don't get hung up on the fact they must come a C-20. They can come from a trailer, mounted or semi-mounted. as long as they have the same part number.
