Finally....Sickle Mower Success
Bobby B
06-28-2003 19:38:45
Finally, today I was able to use my sickle mower with some success. Every time that I have used it, grass seems to clog the bar and I couldn't go 50 feet without stopping to clean off the bar. I sharpened the sickles and increased my ground speed and low and behold it started to work much better!! I'm still trying to convince my wife that I need a disc mower though!!!!
Mark in TN
06-29-2003 13:03:24
 Re: Finally....Sickle Mower Success in reply to Bobby B, 06-28-2003 19:38:45
Purchase a drum mower and your troubles will go away.
mikal
07-01-2003 07:20:25
 Re: Re: Finally....Sickle Mower Success in reply to Mark in TN, 06-29-2003 13:03:24
Drum mowers have their problems to
paul
06-29-2003 09:00:02
I'll bet your ledger plates are dull too if the sickle is. Everything helps a bit.
Is the bar far-end slightly forward? Cuts better than if it is dragging rear-ward.
Every little bit helps.
--->Paul
Brian G.
06-30-2003 06:01:03
 Re: Re: Finally....Sickle Mower Success in reply to paul, 06-29-2003 09:00:02
That's called "lead" and you are absolutely right!!
Dan
06-28-2003 20:38:49
sometimes especially with short hay the momentum helps to carry it over the bar. Short grass is tough to cut anyway. Makes a whole lot happier day when it works huh?
