#8 JD mower seal
Fudd
07-06-2003 21:18:14
The JD # is AH 15738 H but I don't know what the CR crossover # is. I think to get the flywheel off all you do is remove the cotterkey and nut and the thing slides off the splined shaft. I can't remember if it is tapered but I don't think so. You should be able to pop the seal out sith a screwdriver or small prybar. All the 90 wt. will drain out so have some to replace it. Sorry I don't have a good seal number for you. Maybe NAPA can cross reference it for you.
c
07-07-2003 21:37:56
 Re: #8 JD mower seal in reply to Fudd, 07-06-2003 21:18:14
Most of the No.8 mowers have the flywheel seal integral with the Timken bearing. The very last No.8 mowers changed to a separate conventional seal like you are thinking about.
Bob
07-07-2003 08:42:21
I think the removal of the flywheel will require a puller. If I remember correctly, the seal under the mower flywheel is a special tapered roller bearing cone that has the seal molded right to the bearing cone.
