Hesston PT10 Breaking Chain
JOEinMO
07-07-2003 13:11:20
Need your help guys, mowed my hay last week with my old PT10, worked OK the first half, next day, it kept throwing the chain drive off the reel assembly, I tightend it, and it looked a little off center, so I added a new washer to line it up, after about 20 mins, breaks the chain, contined this everytime I fix the chain, any ideas? my big concern is that the reel bearing is going out, but I can move the unit by hand, by rotating the pto shaft, also, any easy way to removed the hay that wraps around that side of the shaft? and how to prevent it? thanks, at least my old MF 41, that I rebuild was still running...
Sid
07-07-2003 17:04:31
 Re: Hesston PT10 Breaking Chain in reply to JOEinMO, 07-07-2003 13:11:20
I have had that problem nd it was the chain was worn. When a roller chain wears it gets slack in the links causing the chain to stretch and it starts riding high on some of the teeth because they do not match like they should causing the chain to jump off when they are very worn they often break when yout try to take out the slack. Also a possibility that the teeh on the sprocket are getting worn too deep.
