1. Bigger bale uses less twine - I'm cheap. But you would be surprised just how much more twine you are using! 2. Stacking - certain size bale works better on the hayrack, for certain unloading devices, etc. - whatever the weight, size can matter. 3. I used to load every bale from the baler on the hayrack, & stack everyone in the drive-in barn mow. I can handle 60lb bales for about 4 hayracks in a day (500 loaded, 350 unloaded - or so - 5 high on the rack, 4 high in the barn - second layer of 4 I drop in an elevator & restack on top). It is FAR less trips walking across the hayrack & barn floor with 850 trips @ 60lbs, than 1700 trips with 30 lbs. I would wear out on the smaller bales, couldn't do it. Dad never did want to help much, & my wife is happy driving the tractor, but can't handle the bales much. (I have a bale basket now, so only handle the bales unloading - but have to carry them farther to get in the barn.) 4. A good 60lb bale is nice & tight, while a smaller bale has a tendency to be light, loose, variable size - or maybe I'm just not adjusting the baler right... ;) 5. If you sell them, buyers have certain expectations. Some horse owners might pay you the same for a light bale they can handle - good deal for you - but others will question the small bales & you will lose a bit on it. 6. No right or wrong, just how it is for me. :) --->Paul
