Anybody used a JD #22 Hay Crimper?
Clancy
07-12-2003 17:05:48
Today I purchased a JD #22 hay crimper. It seems in good shape and I got it for cheap. I needed some help dealing with this red clover. I just can’t get the stuff dried without some sort of help. Haybines, and the like, are way out of my league. Besides, I like to use the old stuff.
As I have no manuals for this critter yet, can someone give me a pretty good rundown on appraising it’s condition or need of repair. And I could use some tips on general operation and what to watch for. I understand that the model was well thought of, in it’s day.
Thanks ahead for your assistance.
Clancy
Clancy
07-13-2003 06:25:52
 Re: Anybody used a JD #22 Hay Crimper? in reply to Clancy, 07-12-2003 17:05:48
Thanks for the help, Guys.
I’ve never used a conditioner. They were just becoming popular when I went off to college. By the time I was around farming again they were distant history.
How high off the ground to I set this thing? It’s probably set high for transport right now but the lower roller must be 6”or more off the ground. Do I need to get down to almost kissing the ground when using it?
Clancy
Rick
07-13-2003 06:25:32
What do you have for a mower. I used to pull crimper right with the mower and did both at same time. Worked pretty slick.
JD70Jim
07-12-2003 19:57:13
My father had the #32 CRUSHER which was very similar. We were able to actualy mow on a wednesday and bale on thursday, using an old #5 mower and the #32. We completely baffled one neighbor who cut his hay at the same time. but his hay took two days to dry, and unfortunately it rained on the 2nd day.
The secret is to run the crimper over the hay as soon as possible after it is cut, and to lay it flat.
As I remember, they were 7 foot machines, and ours was known to snap the adjusting cranks fairly easily. we replaced ours with a CASE 555 (Heston PT10) mower conditioner about 30 years ago.
Get the book.
JD 4020 G
07-12-2003 19:02:54
I had a John Deere 22. It's the best crimper ever made by anyone. The 22 is the last crimper made by John Deere. I have the operators manual and parts book. You can get the books from John Deere.
The direction of travel should be the same as the mower. Their is a crank on each side, for adjusting height. On the other end of the crank, by the spring is the pressure adjusting plate. Loosen the bolt and move the plate up for more pressure. Ordown for less. The average setting is 1 inch from the top.
Check the slip clutch before each season. Block the rolls and use a 4 foot bar, inserted in rear universal joint of telescoping hookup. If clutch will not slip, loosen bolts of clutch until the clutch is free. Then tighten clutch bolts to 50 to 60 inch-pounds.
Keep SAE 80/90 gear lubricant up to the level of the oil fill plug in the gear case.
Clancy
07-13-2003 06:30:46
 Re: Re: Anybody used a JD #22 Hay Crimper? in reply to JD 4020 G, 07-12-2003 19:02:54
JD 4020 G----- -
I noticed that you "had" the crimper and "have" the books! If you'd be interested in parting with your owner's manual and parts catalogue please shoot me an e-mail. Thanks.
Clancy
