John Deere 530 round baler
Alan
07-24-2003 19:01:17
There is a JD 530 Round baler on an auction next week. What size bale does it make? Are they a good baler? What would it be worth? It looks good in the picture. I am curently using a Veermer 605F.
Thanks.
Hay Dr
07-26-2003 12:46:34
 Re: John Deere 530 round baler in reply to Alan, 07-24-2003 19:01:17
It's agood baler. Shake the pickup, If there is alot of movement it will need a pick rebuild, $500-1000. If the belts have the first traction segment worn down then it will not start hay when the hay is in drought conditions. A set of belts is $1600 JD balers need all the traction on the diamond tread belts because the belts turns the bale 100%. You Vermeer has a bottom drum roller to turn the hay.
cannonball
07-25-2003 04:48:33
it makes a 5 x 6 roll...had one for years makes good bales ties the bale slower than newer models because of one arm..have nice day may god bless
