Bush Hog Disassembly?
Russ (NM)
06-25-1999 13:20:30
I need to sharpen the blades on my 4 ft. Howse rotary mower. I removed that nut under the disc, but can't get the disc to come off. I can't reach the nuts that hold the blades while the disc is in place. Is the disc supposed to slip off or does it need to be unscrewed from the shaft coming down from the gear box?
Greg Reuter
06-25-1999 17:15:43
 Re: Bush Hog Disassembly? in reply to Russ (NM), 06-25-1999 13:20:30
Our 4' Howse rotary mower has an access plate
on the deck about 3 inches in diameter. Once
it's off you'll have easy access the nuts if you
have the right socket.
Dennis H.
06-28-1999 11:43:04
 Re: Re: Bush Hog Disassembly? in reply to Greg Reuter, 06-25-1999 17:15:43
I agree on using the access plate for blade removal. A word to the wise is to put everything back together with anti-seize. The acid in the grass will just about "weld" everything under the hog together in a short period of time without it. I don't remove a piece without painting it with the anti-sieze before putting it back. Good luck to you.
VIC(Tx)
06-25-1999 15:24:12
Most bush hog blades can be sharpened from underneath with a small 4 inch hand held grinder without having to remove the blades. On most bush hog cutters there should be a opening on top of the deck so you can use a ratchet and socket to remove the nut that holds the blades .I only remove blades to replace them.
