Pitman problems on NH 46 Sickle mower
Alex
09-15-2003 18:48:50
I replaced the pitman on my 46 but cant figure out how to connect it to the sickle. There is ball and socket joint with a spring in between but cant get the socket tight to the ball and the spring wont stay, if any one has experience with these mowers id appreciate advice, thanks
Kirk
09-16-2003 09:34:58
 Re: Pitman problems on NH 46 Sickle mower in reply to Alex, 09-15-2003 18:48:50
Is the locking lever free to be pushed back all the way to force the two halves to close around the ball on the sickle?
Alex
09-16-2003 18:10:59
 Re: Re: Pitman problems on NH 46 Sickle mower in reply to Kirk, 09-16-2003 09:34:58
The spring is free and i can close it but it wont make any tension to close the ends.
Kirk
09-17-2003 06:15:35
 Re: Re: Re: Pitman problems on NH 46 Sickle mower in reply to Alex, 09-16-2003 18:10:59
Did you replace the whole arm or just the wood? You might have a bad coupler if it is new. They are easy to change so maybe use the old one.
CC
09-15-2003 22:34:38
Go back and look at your old pitman. Sounds like you need to whittle a little bit more and drill the spring hole the same depth as the old one. Comparing the old and new will show you best of all.
