Speeco Post Hole Digger Parts
Al Sawyers
09-20-2003 15:02:09
Does anyone know where I can order replacement cutters & screw point for a Speeco Model 65 Post Hole Digger? Thanks in advance! Al
Mike
09-21-2003 18:46:03
 Re: Speeco Post Hole Digger Parts in reply to Al Sawyers, 09-20-2003 15:02:09
Unless I'm wrong, Speeco makes the phd's that Tractor Supply sells. Is there one near you? You should be able to get them there. I have also ordered them direct from Speeco.
RJ-Az
09-20-2003 18:54:42
I usually do a build up and hard face on them. I have taken the screw point and with a piece of flat truck spring made a "FishTail" point that works better in our caliche soils. If you don't have a welder any good shop should be able to help you out.
