I'm sure others will have better hints than I do, but getting a few answers from you will help them: What type of soil are you working in? Hard packed clay with sod & big root clumps, or soft loose sany soil? (I'll guess close to the first?) Wet or dry soil? It all makes a difference. Is this a pull type plow or mounted on the tractor? A lot of pull type plows work in heavy soil better with a 75-100 lb rock on them... Are there coulters (round cuttting disks) and are they big enough, & lined up right? Are the plow lays (bottom cutting edge of the bottom, almost always a seperate piece that wears the most & is replaceable) in good condition? This is often the biggest problem. Are the plow bottoms clean & shiny, or old & rusty & pitted or painted? it's real tough to get a rusty plow going, you'll need to fight a long time until it shines itself up. One round in sandy ground will do it, while a whole day in wet clay or peat probably still won't clean them up. Then you need to get all the angles adjusted right, this is the part others can help you with. (I used to plow with a 2 & 3 bottom pull plow, now I have a bigger semi-mounted so I don't remember the details...) The fisrt round is harder to set up anyhow, after that following in the furrow seems to line up easier. --->Paul
